Hi everyone, I have a questionIt is possible to hide popup for a selected objects without losing the selection?Just to leave highlighted object and minimize pop-up window? Can it be changed somewhere in code to enable this? Thanks,Robert
Hi @RobertPiatek,
Thank you for your question. Based on the information you have provided, I believe the Select Widget may meet your requirements. This tool allows for multiple features to be selected without displaying a pop-up. I have attached an image with an example of the results below. More information can also be found here: Select widget—ArcGIS Web AppBuilder | Documentation
Alternatively, you can create a Web Map with the required layers and disable the pop-ups in the layer configuration. Please see Configure pop-ups (Map Viewer)—ArcGIS Online Help | Documentation for more information.
Regards,
ログインすると、投稿したり、更新をフォローしたりできます。初めてですか?無料アカウントを登録しましょう。
