I'm trying to create a basemap with my own styles and the page never finishes loading the predefined ones so I can edit the colours.
In the console I get some errors that you can see in the attached image.
Anybody has the same problem, any solution?
And is this happening in ArcGIS Online, or an Enterprise Portal? What basemap are you trying to open in the style editor?
Are you doing it from the map viewer, or directly via the developer portal: https://developers.arcgis.com/vector-tile-style-editor/(modal:new)
@LibertadChapinal
can you share the link you are using? are you logged in to your arcgis account when you load this page? and please share which browser version you are using.
@LibertadChapinal I'm working to track down this issue but I have a few questions:
Yes, it happens if I try to access directly through a direct link. I've got a developer account and I'm trying to create a new one, not one that has already been edited I have recorded this short video where you can see the error better.
I am having this same issue as well. Does anyone have an alternative solution?
August
@AugustNastasi can you give us more specific details as to what is happening and the error you are seeing, and how you are loading the style editor? We are unable to reproduce any issue on our end but we don't know all the details to your experience.
Try to access form the developers' page, it worked for me! Logged into developers.arcgis.com, you can find the editor in Layers > New vector basemap style
When I logged onto the Vector Tile Style Editor this morning it was working fine until I refreshed my page after it had froze. Since then, the basemap appears blank.
@AugustNastasi Did any error message appear?
Is it possible you can try to log in again and then refresh this page, let me know what happens.
Thanks for reporting this.
@John-Foster even after logging out and on again I am still experiencing this same problem. There are no error messages, and the tile style editor is still able to make changes to color, text, etc. but I am unable to see these changes as the reference map is blank. Additionally, I am able to save my work, however this isn't very useful since I cannot inspect changes as I make them.
