Hello Linda
The updateDataGrid.txt does not have any logic to update the server. i.e. no code is calling the featurelayer.applyedits method. the store.setValue updates only the memory variables so as long, you dont search again the values you have updated will remain. But if you get the records again from the service. The original values will be returned.
Hope this answers your doubt.
Thejus
Thanks thejus, this makes sense! Forgive my ignorance - with the existing code above, what would be the easiest way to commit the edits to the server?
ログインすると、投稿したり、更新をフォローしたりできます。初めてですか?無料アカウントを登録しましょう。
