Hi, I have flood plain or stormwater , location of all the asset within an area. I am trying to identify which assets are at risk.
If the pinkish area is the flood plain, go with my suggestions
select by location for the points and polygons
and intersect for the lines
Select features by location—ArcGIS Pro | Documentation
Is a possibility, also one of the Overlay tools, like Intersect or Pairwise Intersect
An overview of the Overlay toolset—ArcGIS Pro | Documentation
would be a good start, depending what and how you intend to do the identification
Thank You ! I will do this. what about DEM? https://pro.arcgis.com/en/pro-app/latest/tool-reference/spatial-analyst/exploring-digital-elevation-models.htm
What do you intend to do with a DEM?
If it doesn't add to the analysis, don't just start adding things. Your work will lose focus 😉
I will give this one a try and let you know. Thank You
