Dear Community,
I have built my corona virus tracker website and pulled these 2 api's:1) https://services1.arcgis.com/0MSEUqKaxRlEPj5g/arcgis/rest/services/ncov_cases/FeatureServer/2/query?f=json&where=Confirmed%20%3E%200&returnGeometry=false&spatialRel=esriSpatialRelIntersects&outFields=*&orderByFields=Confirmed%20desc&resultOffset=0&resultRecordCount=200&cacheHint=true
2) https://services1.arcgis.com/0MSEUqKaxRlEPj5g/arcgis/rest/services/ncov_cases/FeatureServer/1?f=json
At the moment, USA, Sweden, Belgium & Serbia doesn't seem to load the "recovered" stats. Can anyone kindly assist me on what to do to solve this matter please?
Thank you in advance.
This is the exact code from the source file. It says "null" for these 4 countries.
The issue is likely with the source data, and not with your queries. Check the attached Excel for the null data countries for "Recovered" Field (Belgium, Kiribati, Serbia, Sweden, US).
The issue needs to be fixed by the author of the data.
Hi thanks, so the author has to fix this right? Who is the author of this code? How to reach him ?
Just my guess.
It looks like John Hopkins' data/service.
Although I am not sure, but I think Lauren Gardner might be the one to connect.
Thanks a bunch Jayanta Poddar, I truly appreciate your gestures.
Dear Lauren Gardner, hope you will see this thread and respond if this areas can be fixed from the API source.
Lauren's contact info can be found in the link above. You might like to send a mail to her. She is not active in the Esri Community currently.
@DeanoK you may be able to find other data by this user CSSE_GISandData at https://esriinc.maps.arcgis.com/home/user.html?user=CSSE_GISandData and on some of those item description pages there is contact information, for example this item https://esriinc.maps.arcgis.com/home/item.html?id=628578697fb24d8ea4c32fa0c5ae1843
