I'm trying to run a rule file in CityEngine 2016. When I try to Assign the Rule I get a pop up message saying "No Start Rule found in 'RuleFileName.cga'. Verify the rule file." (Capture 1).
However, I have a @StartRule in my rule file (Capture 2 shows a snippet of the code).
Is there something I'm missing?
Looks like your start rule is a conditional statement (case/else) but your missing the else part.
Put "Else:" at the bottom with what you want the default to be.
