ArcGIS 10.7 用の HEC-GeoHMS インストールパッケージは、存在しない ArcHydro のバージョン 10.7.0.19) を探しており、最も近いバージョンである 10.7.0.18 または 10.7.0.2 ではインストールできません。<\/P><\/BODY><\/HTML>
The GeoHMS setup should have installed Arc Hydro 10.7.0.19 but it looks like it fails on an incorrect version check for ArcGIS (10.6 instead of 10.7).
We will fix the setup. Meanwhile I have posted the 10.7.0.19 setup for Arc Hydro.
Christine
Please attach the link for Arc Hydro 10.0.7.19
I can't fins it anywhere
It has not refreshed yet so you need to match the number to see it:
https://downloads.esri.com/archydro/archydro/Setup/10.7/10.7.0.19/
Great, thanks.
Hi Christine !
I have the same problem. I just downloaded today the installer for HEC-GeoHMS 10.7 and it looks for the installation of ArcGIS 10.6 instead of 10.7.1. Did you updated the installer ?
Thanks !
We created a new setup but forgot to post it. Here it is:
http://downloads.esri.com/archydro/HECGeoHMS/Setup10_7/10.7.0.4/
