I use ESRI's FeatureTable widget (4.x)
https://developers.arcgis.com/javascript/latest/sample-code/widgets-featuretable-map/
I want to customize it somehow. On the Grid's top-right the ... represents the "Options". How can it be set off?
Thanks.
Adding this to the CSS will remove the button
.esri-feature-table__menu .esri-button-menu { display: none; }
Thanks for your response. In my app, I created a dynamic table as shown below:
contx.myTable = new mv.esriModules.FeatureTable({layer: contx.myFeatureLayer,visibleElements: { selectionColumn: false },fieldConfigs: _fieldsConfig,container: document.getElementById("tableDiv")});
How can the style be added dynamically? Thanks.
If you don't want to add it to the CSS style section in your html, you can add it dynamically several different ways: https://developer.mozilla.org/en-US/docs/Web/API/CSS_Object_Model/Using_dynamic_styling_information
KenBuja: Resolved. Thanks a lot!
Glad to help. Don't forget to click the Accept as Solution button or post how you resolved it.
Hello @KenBuja . Where can see all available css properties for the feature table or all esri widgets? Thank you.
The widget pages should have a link to the css information in the See Also section
You can also right click on the widget and use the Inspect option to get more information about all of its CSS.
Thank you @KenBuja . I am surprised that there is no css to change background color of rows. Only when you hover over it or select it.
ShaningYu,
Could you share your solution? I have a similar problem. I'm trying to change the background color of a cell based on the value on another cell.
Thanks!
