ArcGIS Pro: 2.4.2: In general, ArcPro has less performance than ArcMap,
I observed that the ArcPro has less performance than ArcMap. This observation is related to all tools and behaviors
I have noticed significant delays in general navigation through the application. Which gets especially bad if you are faster than the application itself.
Examples:
Here's another important feature missing from ArcGIS Pro that's in ArcMap. Please give it an up-vote.
ArcGIS Pro: Enable "Add all values" to use format settings from "All Other Values"
Also missing in Pro is the home and default gdb options on the export window (for both data and pdfs):
How about your experience in 2.7.2?
