こんにちは、<\/P>
<\/P>
Power BIで使用されるArcGIS enterpriseまたはArcGIS Onlineの組織参照レイヤー内に、ArcGIS Maps for Power BIを使って独自の境界線を作成し、LOCATIONフィールドを使ってこれらのカスタム境界線上でZIPコードをLOCATIONフィールドに使用する場合のようにフィルターやインタラクションを行うことができるかどうか疑問に思っています。<\/P><\/BODY><\/HTML>
Hello,
Are you talking about using a reference layer boundaries to select locations?
If so, this is possible. See the following link:
Work with layers—ArcGIS Maps for Power BI | Documentation
Mark
Hello Mark,
I have the same question, and I need to show my own polygon layer symbolized with the data selected using Power BI. Not reference layer.
Is it possible?
Thanks
Ofra A.
Hello Ofra,
Yes but under the condition that the polygon in question is an administrative boundary found within the Esri World Geocoder. (such as a county, etc). At this time, it is not possible to drag in your own Polygon data.
Hi JonEmch,
We support clients that have to run behind firewalls and have no internet access e.g. security agencies and defense. We can use ArcGIS Enterprise and Power BI Reporting Server. What do we do about the Geocoding, Drivetime, Basemaps and Boundary Location layers that are only available online only?
Any ideas?
Thank you
Rudolf
Hey there Rudolf,
ArcGIS for PowerBI is supported on PowerBI Report Server which runs in an online state. Unfortunately, this excludes offline / disconnected environments at this time. Please see the blog from the Microsoft Integration Product Manager below: https://www.esri.com/arcgis-blog/products/power-bi/announcements/arcgis-for-power-bi-is-now-in-report-server/
