I've configured popups for hydrants in ArcGIS Pro to show a hyperlink as well as a few of the field attributes. It looks perfect in Pro, but when I share it as a web layer the popup only shows the hyperlink without any of the other fields. I know that I can manually add those fields to the popup in the web map, but that's time consuming and will have to be redone anytime we redo the map. Having the popups show up in the web map the exact way they do in Pro would be very convenient. Is there a way to make this work? Am I missing Something? I've attached pictures of the difference between Pro and the web map in Portal for reference.
