Hi?
Please, define "Arcgis Pro 2.7 is the last version "
Read the documentation on this warning, it provides additional information: 24129: ArcGIS Pro 2.7 is the last version that will support packaging '<value>'.—ArcGIS Pro | Documentation
DescriptionThe locator included in the package was created with the Create Address Locator tool. Locators created with the Create Address Locator tool will not be included in mobile map packages after the ArcGIS Pro 2.7 release.SolutionRe-create the locator in ArcGIS Pro using the Create Locator or Create Feature Locator tool.
Sounds to me like it is a warning that M14 will be supported (whatever M14 is). So don't expect it in ArcGIS Pro 2.8
Is the D:W21_EMAPWLOCAWM14.loc an old address locator? Can you remove the *.loc from the project via the Catalog Pane and try to create the *.mmpk again?
Thank you so much~
