I'm a beginner in ArcPy and I want to perform some tasks using ArcPy but I am not getting results.
I have a layer named survey in my current MXD and I want to select each polygon in surveyand export to JPEG and this is my script:
mxd = arcpy.mapping.MapDocument("CURRENT") df = arcpy.mapping.ListDataFrames(mxd)[0] titleElement = arcpy.mapping.ListLayoutElements(mxd, "TEXT_ELEMENT") rows = arcpy.SearchCursor("survey selection") for row in rows: titleElement = row.VendorFarm query = '"FID"=' + str(row.FID) arcpy.SelectLayerByAttribute_management("survey selection", "NEW_SELECTION", query) df.zoomToSelectedFeatures() arcpy.RefreshActiveView() del rows del row
As @DavidPike suggests, you should use the da.SearchCursor. I noticed that you are attempting to access and set a map title using ListLayoutElements . This will return a list, and you will need to access the proper text element. It might be easier if you use the dynamic map "Title" as this property can be accessed and changed. Here's a code snippet which illustrates these ideas. Since it looks like you are using shape files, you may need to make some changes.
mxd = arcpy.mapping.MapDocument("CURRENT") df = arcpy.mapping.ListDataFrames(mxd)[0] feature = 'survey selection' fields = ['OID@', 'VendorFarm'] # OID@ is ObjectID token (see search cursor help) jpgPath = r"C:\Path\For\JPGs" # save location for jpgs # clear any existing selections arcpy.SelectLayerByAttribute_management(feature, "CLEAR_SELECTION") with arcpy.da.SearchCursor(feature, fields) as cursor: for FID, VendorFarm in cursor: # unpack each row by assigning to field name variables mxd.title = VendorFarm query = '"FID" = {}'.format(str(FID)) arcpy.SelectLayerByAttribute_management(feature, "NEW_SELECTION", query) df.zoomToSelectedFeatures() arcpy.RefreshActiveView() jpg = "{}\\{}.jpg".format(jpgPath, VendorFarm) # assuming VendorFarm is valid filename arcpy.mapping.ExportToJPEG (mxd, jpg)
If you need to use the ListLayoutElements, I would suggest that your map's text elements be named as this will help you find the correct element. Just a rough code snippet to illustrate:
titleElement = arcpy.mapping.ListLayoutElements(mxd, "TEXT_ELEMENT") for t in titleElement: if t.name == 'MapTitle' t.text = 'Some New Text'
Hope this helps.
You just need to throw in ExportToJPEG—Help | ArcGIS for Desktop within the loop (after refreshactiveview).
do something like concatenate an outpath with what you have already - str(row.FID)
I'd recommend using the arcpy.da cursor rather than the arcpy cursor.
SearchCursor—Help | ArcGIS for Desktop
It will require some change of syntax, though if you plan on working with cursors again, it's best to adopt the da cursor from the onset.
ログインすると、投稿したり、更新をフォローしたりできます。初めてですか?無料アカウントを登録しましょう。
