Hi guys,
I am just wondering if I can export attribute table to CSV?
I have seen this functionality in other apps but can this be done without any type of licence?
I think this is a Portal question rather than Pro.
Attribute Table widget—Portal for ArcGIS | Documentation for ArcGIS Enterprise
There's a checkbox in the Widget, I'm pretty sure there's also the option to export in a Web Map via the attribute table interface,
Thanks @DavidPike Issue was down to firefox and internet edge where this functionality does not work. I tried it in chrome and works fine.
have you tried with alternate browsers? Does it s[pin or just nothing at all happens? What about checking the browser developer console?
Thanks @DavidPike
I have enabled this. Only issue is when I hit export, nothing happens. Will have to see what happens
@cardiokan https://community.esri.com/t5/arcgis-pro-questions/arc-pro-copy-past-attribute-table-into-excel/td-p/30839
Look here. You can copy the data and past to excel.
