After further testing of the map question in Survey123, it appears that it is using the World Geocoder. Is there any way for a public survey to use our organization's geocoder instead of the World Geocoder? Or at the very least in addition to? The World Geocoder doesn't find half the addresses in our county. It is woefully out of date (by many years). Our geocoder finds every address in our county and has suggestions. This is a deal breaker for using the map question for us. Is there a way to use our geocoder and not the ESRI World geocoder? TIA!
I did post this same question here back in August but no replies:
https://community.esri.com/t5/arcgis-survey123-blog/pulling-data-from-geopoint-questions/ba-p/896838?commentID=90995&et=blogs.comment.created#comment-90995
