While editing allow split line on vertices and Split line on point with in the Optional Output feature class.
Should have option to split line on vertices without now output.
Hi Adnan Zahoor Abbasi Could you please clarify whether this is an idea/question about editing or geoprocessing? The description talks about splitting a line while editing, but then you show a screenshot of the Points to Line geoprocessing tool.
Also there is a split line by vertices tool and split line by points tool? So not sure what you are asking?
Dear Kory Kramer, Tanks for replay, It is an Idea that while working in the session split line or selected lines on vertex.
or geoprocessing tool where Output should be optional.
Hi @Adnan_ZahoorAbbasi1 The Split Into COGO Lines tool sounds like it will work for you. Documentation link: https://pro.arcgis.com/en/pro-app/help/editing/split-lines-into-cogo-lines.htm
Scott
Greetings, Scott_Harris Thanks a lot.
Regards,
Adnan Zahoor Abbasi
I'm happy to help, @Adnan_ZahoorAbbasi
Since it sounds like the software already offers the functionality you requested in this Idea, I'll set this idea to Already Offered.
投稿、コンテンツのフォローなどにはサインインしてください。初めてですか?無料で登録しましょう。
