I was wondering if anyone could help me with some R- script I got from a client, and I want to integrate it to my Model Builder. I have installed R-ArcGIS bridge and all required packages, and tested the script as standalone tool with hard-coded parameters and it works fine. The problem I have is how to create variables for the input and output parameters.
If you get a chance, will you spend few hour to assist with the attached R script. I tried to use the in_params & out_params for inputs and outputs respectively, but no luck except the path to the folder.
