I'm documenting the workflow of creating a hosted feature layer and then using Collector on Windows 10 for offline data collection. Once back from the field after synchronizing the offline edits I realized that the coordinate system of the hosted feature layer is UTM in Meters. I went back to the process of creating a feature layer to determine if there's a step where the projection can be defined. I didn't see anything.
I'm assuming that the projection of the feature layer cannot be changed at this point. Is that correct?
Does the feature layer adopt the same projection as the basemap defined?
