I have inserted two 3D objects from outside CityEngine using the i() operation. When I apply a texture to these objects, they become really dark (although still textured). The first series of objects I tested this on work correctly...and still work correctly when I re-generate, but every other instance of the same operation results in the darker objects. I have tried set(material.colormap,x) as well as texture(x). See attached.
