I am trying to:
1- Iterate through each polling place
2- Select polling within precinct (by location)
3- select that precinct ( by location)
4- select adjacent precinct ( intersect precinct)
5- select all voters inside adjacent precincts then calculate field by adding "Near" value.
6 Switch selection to get voters outside precincts then calculate field by adding "Far" value.
Attached model is doing the task the only problem its doing it for the last record. I have 85 polling place.. and I am getting only the last one.. if I stopped the model in middle the model calculate the record in middle. How to fix the Model so I can calculate all the Fields.
