When you submit survey123 form which contains calculations. ex: no of boys and number of men it works well at the beginning. When you try to update the information in the inbox it doesn't recalculate the total number of female.
I need help
Hi Oussama,
Can you please confirm the version of Survey123 you are using? We recently released an update that should be addressing this issue.
its 3.0.132
Please update your version of Survey123 - a change was made this month to address this calculation behavior. See Minor Update to Survey123 Available (August 16, 2018) for more information.
Hi James,
It works well if you tried to enter new/Update survey123 with the new version, but it didn't work with the old entered surveys when you try to update them.
Best,
Oussama
Did the ones that are not working well have their values changed while the calculations were not working? If so, then the values may be out of sync with the calculations and are being interpreted as manual entry.
Thanks. Very useful. I fixed it manually from arcgispro. then it works well.
Sorry again for disturbing you but I have a different question. I would like to change the resubmit message for a survey which is already developed in Survey123 connect. On the other hand I can change the message for surveys created initially in the web.
Currently you cannot change the resubmit message for surveys authored by Survey123 Connect. We have this logged as an enhancement.
We've made an enhancement in 3.3 release to allow editing the thank you screen content of Survey123 Connect surveys directly in the Design page of Survey123 website, just as you edit it for the surveys published from the website. Please be noticed after editing and publishing the survey on the website, you have to use 3.3 or higher version of the web app to see the result.
The 3.3 release is planned before the Dev Summit, please stay tuned with our release blog and doc to find more details.
Thanks again for your feedback!
サインインしたメンバーは投稿、更新のフォローなどができます。初めてですか?無料アカウントを登録してください。
