I created a web map from a survey. However the fields are out of order in the web map. I logged into survey123, fixed this and republished the survey. The changes are not reflected in the web map however.. I recreated the web map from the fixed survey and the fields are still out of order.. I really don't want to create it again. Is there a way to publish this simple adjustment without starting over?
