Hi all, I'm having trouble with Roberts Identify Widget. The issue I'm having is with a specific layer, Parcels. It won't return any results when I select it from the drop down, however it does identify when I select all layers. However none of the fields or popup attributes i set for it remain. It just displays everything. I have attached the json from my "C:\WAB\server\apps\3\widgets\Identify" folder. I also noticed the json doesn't save the configuration I setup for it. Perhaps this is the wrong json file.
http://services5.arcgis.com/xfq44TYLhoTF2Raq/ArcGIS/rest/services/Parcels/FeatureServer/0
