Power BIのマップにグローバル(米国以外)の人口統計データを追加するために、Plusサブスクリプションのトライアルを購入しました。しかし、インターフェースを通じて利用可能なものはないようです。例えば、このLiving Atlas情報(https:\/\/www.arcgis.com\/home\/item.html?id=b01adaf9e5584d09a147d14924d9cdb5<\/A>)を使いたいのですが、タイトルや類似のキーワードで検索しても結果が返ってきません。何か間違っているのでしょうか?<\/P><\/BODY><\/HTML>
Good Morning
I am also interested in getting more Living Atlas content in power BI. In particular the Active Hurricane feeds from the NHC that the Living Atlas does provide quite nicely in AGOL.
Regards.
Jeremy.
Hello Jeremy and Richard,
Thank you for reach out! My apologies for the lengthy delay between when this was posted and this response. I am a Product Engineer for the ArcGIS Maps for Power BI application here at Esri, and I wanted to get in touch to respond.
We are currently researching this as others have made similar comments to the Living Atlas structure and where it generates the layers from and how ArcGIS Maps for Power BI interprets them. Once we have a bit more insight on these inquiries, I will respond back and let you both know.
Thank you,
Anthony
I'd also be very interested in this development. It was the reason I signed up for a Plus account.
Please have a look at this documentation location for some answers: https://doc.arcgis.com/en/maps-for-powerbi/design/add-a-reference-layer.htm
"A reference layer must be a feature service that contains a single layer. ArcGIS Maps for Power BI filters out unsupported item types; if you don't see the item you're looking for, verify that the layer is saved as a single-layer feature service in ArcGIS."
I believe this is what you are experiencing.
サインインしたメンバーは投稿、更新のフォローなどができます。初めてですか?無料アカウントを登録してください。
