I have a model builder / clip function questions, and I think the best way to describe my question, and find a solution how to create a functional model is this:
Say that I have a (polygon) layer called USA.shp, and one of attributes in the attribute table is "State_ID". Every State_ID would be unique number from 01, 02, 03...50.
Then I have three vector layers as follows: 1) a nationwide (Polygon) layer called "Lakes" with related attribute table which represent all the lakes in USA, 2) a nationwide (Point) layer called "Cities" with related attribute table which represent all the cities in USA, and 3) a nationwide (Lines) layer called "Highways" with related attribute table which represent all the highways in USA.
Basically, I would like to create a model that, after it's run it course, I would have 50 individual folders that contains all my points, lines and polygons based on their "State_ID".
This is just a fictional question but I wanted to keep it simple. My real task is somewhat similar but it requires to clip (and create) multiple individual folders with vector data based on just that region, or "State_ID".
How would you start building the model? Do you create first 50 individual folders where the output will go? What would be your input folders and how it can be clipped to 50 different shape-files?
Please feel free to change the scenario, or change the attribute table as needed.
