Hello fellows,
I want to install the ArcGIS API for Python , I proceed as state at https://developers.arcgis.com/python/guide/install-and-set-up/#Install-using-Anaconda-for-Python-Distribution
but get the following error:
conda install -c esri arcgis
Solving environment: failed
UnsatisfiableError: The following specifications were found to be in conflict:
- arcgis
- xlsxwriter
Use "conda info <package>" to see the dependencies for each package.
then I tried the following command:
conda install arcgis
PackagesNotFoundError: The following packages are not available from current channels:
- arcgis
Current channels:
- https://repo.continuum.io/pkgs/main/win-64
- https://repo.continuum.io/pkgs/main/noarch
- https://repo.continuum.io/pkgs/free/win-64
- https://repo.continuum.io/pkgs/free/noarch
- https://repo.continuum.io/pkgs/r/win-64
- https://repo.continuum.io/pkgs/r/noarch
- https://repo.continuum.io/pkgs/pro/win-64
- https://repo.continuum.io/pkgs/pro/noarch
- https://repo.continuum.io/pkgs/msys2/win-64
- https://repo.continuum.io/pkgs/msys2/noarch
I check for the info of conda:
conda info
active environment : base
active env location : C:\Users\CGLondono\AppData\Local\Continuum\anaconda2
shell level : 1
user config file : C:\Users\CGLondono\.condarc
populated config files :
conda version : 4.4.10
conda-build version : 3.4.1
python version : 2.7.14.final.0
base environment : C:\Users\CGLondono\AppData\Local\Continuum\anaconda2 (writable)
channel URLs : https://repo.continuum.io/pkgs/main/win-64
package cache : C:\Users\CGLondono\AppData\Local\Continuum\anaconda2\pkgs
C:\Users\CGLondono\AppData\Local\conda\conda\pkgs
envs directories : C:\Users\CGLondono\AppData\Local\Continuum\anaconda2\envs
C:\Users\CGLondono\AppData\Local\conda\conda\envs
C:\Users\CGLondono\.conda\envs
platform : win-64
user-agent : conda/4.4.10 requests/2.18.4 CPython/2.7.14 Windows/10 Windows/10.0.16299
administrator : False
netrc file : None
offline mode : False
What I am missing???
