I relatively new to the Enterprise Geodatabase world and was given a bunch of old .sde connection files created in 2013 (Which were created before I got the job, and I am assuming on an older SQL Server).
I was tasked to create a Utility Network using the .sde feature classes, which required an update to a 2016 SQL Server. After updating the SQL Server, Arcpro requires an update to the Geodatabase itself, which is done.
After updating the two, I tried again to create the utility network and now getting the error:
"Error creating database user. [Must be connected as database system admin/superuser to create new geodatabase,user,or tablespace]. "
I cant even edit the feature classes in the .sde (2016) now and am getting the error:
"Table registered as versioned with a different model than the connected version"
I am spinning my wheels and unsure how to even ask or google the right question. Is this due to the SQL server permissions? If so, what permissions do I ask IT for in order to create a new database user?
Resources on .sde's / Enterprise Geodatabase Administration for beginners (For non-IT folks like me) / Table Versions etc would be greatly appreciated as I cant seem to find much online.
Thank you!
Sarah Ramirez
Sarahramirez995@gmail.com
