I'm looking for a way to pass a feature class attribute to my survey when I select on a feature (could be points / lines / polygons) on the map section of Survey123. Anyone can help me on that? I know you can pass attributes from Collector or Explorer using the URL scheme but it is not a workflow I want to use at the moment. Only Survey123 in this case. Thanks!
