Different types of ImageSource with PictureMarkerSymbol
PictureMarkerSymbol takes an ImageSource as its Source property.
When I create a PictureMarkerSymbol using a valid BitmapSource, which is a descendent of ImageSource, I get a TargetInvocationExeption. The InnerException is as follows:
InnerException: System.NotSupportedException
Message=Specified method is not supported.
Source=ESRI.ArcGIS.Client
StackTrace:
at ESRI.ArcGIS.Client.Symbols.PictureMarkerSymbol.ToJsonInternal(Action jsonReady, Boolean& dataPending, Boolean nativeMapSerialization)
at ESRI.ArcGIS.Client.Symbols.PictureMarkerSymbol.ESRI.ArcGIS.Client.IJsonSerializableAsync.ToJson(Action jsonReady, Boolean& dataPending)
at ESRI.ArcGIS.Client.JsonSerializableExtensions.SerializeToJson(Object o, Action jsonReady, Boolean& dataPending)
at ESRI.ArcGIS.Client.Runtime.NativeGraphicsLayer.GetSymbolJson(Graphic graphic, Action jsonReady, Boolean& dataPending)
at ESRI.ArcGIS.Client.Runtime.NativeGraphicsLayer.AddGraphic(Graphic graphic, Geometry displayGeometry)
at ESRI.ArcGIS.Client.Runtime.NativeGraphicsLayer.AddGraphics()
at ESRI.ArcGIS.Client.Runtime.NativeGraphicsLayer.Initialize()
at ESRI.ArcGIS.Client.NativeMap.AddLayer(Int32 index, Layer layer)
at ESRI.ArcGIS.Client.DrawingSurface.AddLayer(Int32 index, Layer layer)
at ESRI.ArcGIS.Client.AcceleratedDisplayLayers.TryAddLayerToDrawSurface(Layer layer, Int32 index)
at ESRI.ArcGIS.Client.AcceleratedDisplayLayers.Draw(Envelope extent, Double resolution, MapPoint canvasOrigin, Boolean useTransitions, Boolean isContinuous)
at ESRI.ArcGIS.Client.Map.loadLayerInView(Boolean useTransitions, Envelope drawExtent, Layer layer, Boolean isContinuous, Double scale)
at ESRI.ArcGIS.Client.Map.loadLayersInView(Boolean useTransitions, Envelope drawExtent)
at ESRI.ArcGIS.Client.Map.Layers_LayersInitialized(Object sender, EventArgs args)
at ESRI.ArcGIS.Client.Map.<>c__DisplayClass10.<Layers_LayersInitialized>b__e()
InnerException:
Is PictureMarkerSymbol depending on ImageSource being a BitmapFrameDecoded? I forgot to mention that this is in the WPF Runtime SDK 1.0.
