I'm modifying the createDBF developer sample function with VB 2008 Express (Create a new DBASE file). I think I've got everything worked out except for dealing with an "Optional parameters must specify a default value" error that comes up, in regard to the Optional pFields parameter. Can anyone get me on track with what the default might look like? Optional pFields As IFields = ???
Public Function createDBF(strName As String, strFolder As String, Optional pFields As IFields) As ITable
' createDBF: simple function to create a DBASE file.
' note: the name of the DBASE file should not contain the .dbf extension
On Error GoTo EH
' Open the Workspace
Dim pFWS As IFeatureWorkspace
Dim pWorkspaceFactory As IWorkspaceFactory
Dim fs As Object
Dim pFieldsEdit As IFieldsEdit
Dim pFieldEdit As IFieldEdit
Dim pField As IField
pWorkspaceFactory = New ShapefileWorkspaceFactory
fs = CreateObject("Scripting.FileSystemObject")
If Not fs.FolderExists(strFolder) Then
MsgBox("Folder does not exist: " & vbCr & strFolder)
Exit Function
End If
pFWS = pWorkspaceFactory.OpenFromFile(strFolder, 0)
' if a fields collection is not passed in then create one
If pFields Is Nothing Then
' create the fields used by our object
pFields = New Fields
pFieldsEdit = pFields
pFieldsEdit.FieldCount_2 = 1
'Create text Field
pField = New Field
pFieldEdit = pField
With pFieldEdit
.Length_2 = 30
.Name_2 = "TextField"
.Type_2 = esriFieldType.esriFieldTypeString
End With
pFieldsEdit.Field_2(0) = pField
End If
createDBF = pFWS.CreateTable(strName, pFields, Nothing, Nothing, "")
Exit Function
EH:
MsgBox(Err.Description, vbInformation, "createDBF")
End Function
