<div id="navToolbar" > <div id="zoomin" onClick="HIGHLIGHT ME; navToolbar.activate(esri.toolbars.Navigation.ZOOM_IN);">Zoom In</div> <div id="zoomout" onClick="HIGHLIGHT ME; navToolbar.activate(esri.toolbars.Navigation.ZOOM_OUT);">Zoom Out</div> .... <div id="deactivate" onClick="UNHIGHLIGHT OTHERS; navToolbar.deactivate()">Deactivate</div> </div>
//this toggles the button highlight in the toolbar to show which tool is currently active //note - doesn't do the FullExtent since it's a button not a togglebutton function toggleButtonIcon(tool) { //only the tools in the toolbar are dijit togglebuttons so can iterate thru them dijit.registry.byClass("dijit.form.ToggleButton").forEach(function(togbtn) { if (togbtn == tool) { togbtn.attr("checked", true); } else { togbtn.attr("checked", false); } }); }
Do you know why dijit.registry.byClass may cause a TypeError? I'm getting dijit.registry.byClass is not a function. dijit/registry is already a requirement..
Note that for backwards compatibility, the dijit.registry global variable (as opposed to the dijit/registry module) includes array iterator methods (forEach, filter, byClass, map, every, and some). However, AMD code should not expect these functions to be available in the Object returned from require([“dijit/registry”]).
Okay, yes...I just read that as well. I'm now confused by my options, but I'll probably open a new thread unless you have a quick tip.
サインインしたメンバーは投稿、更新のフォローなどができます。初めてですか?無料アカウントを登録してください。
