void geoprocessorTask_GetResultDataCompleted(object sender, GPParameterEventArgs ev1) { if (ev1.Parameter is GPDataFile) { GPDataFile ClipResultFile = ev1.Parameter as GPDataFile; if (String.IsNullOrEmpty(ClipResultFile.Url)) return; MessageBoxResult res = MessageBox.Show("Data file created. Would you like to download the file?", "Geoprocessing Task Success", MessageBoxButton.OKCancel); if (res == MessageBoxResult.OK) { WebClient webClient = new WebClient(); webClient.OpenReadCompleted += (s, ev) => { streamedDataFile = ev.Result; }; webClient.OpenReadAsync(new Uri((ev1.Parameter as GPDataFile).Url), UriKind.Absolute); mywindow = mywindow ?? new ExtractAsbuilts(); MapApplication.Current.ShowWindow("Selected Asbuilts", mywindow); } } } private void SaveButton_Click(object sender, RoutedEventArgs e) { SaveFileDialog dialog = new SaveFileDialog(); dialog.DefaultFileName = "output.zip"; dialog.Filter = "Zip file (*.zip)|*.zip"; bool? dialogResult = dialog.ShowDialog(); if (dialogResult != true) return; try { using (Stream fs = (Stream)dialog.OpenFile()) { streamedDataFile.CopyTo(fs); fs.Flush(); fs.Close(); streamedDataFile = null; } } catch (Exception ex) { MessageBox.Show("Error saving file :" + ex.Message); } }
サインインしたメンバーは投稿、更新のフォローなどができます。初めてですか?無料アカウントを登録してください。
