I have a question regarding if data will be lost. if you had say 5 Survey123 inspections in your outbox because a required field was not autopopulating from an Arcade expression occasionally (oddly only Android devices) would those inspections be lost if you pushed a survey123 form update. The Survey123 hosted feature layer schema would not change at all and only change to the form would be making 1 text field editable instead of read only so a number could be typed in and the surveys submitted. Any help would be appreciated. Thank you.
