In 2D mapping we have the mapView.AddOverlay method to add a graphic point on the map (e.g., often used to add a graphic point where the user just clicked). In a 3D scene what is the equivalent command since mapView.AddOverlay is not supported in 3D?
Secondly, for scenes a we need to use ConstructMarker vs. ConstructPointSymbol to build a simple 3d marker (e.g., pushpin) to display. Would this work or is their a 3d simple marker style I should be using?
SymbolFactory.Instance.ConstructMarker(ColorFactory.Instance.CreateRGBColor(255, 255, 0), 10.0, SimpleMarkerStyle.Pushpin);
Any pointers would be appreciated.
Rich
arcgis pro api #ArcGIS pro
