I think you have found the answer to your own problem. Unfortunately, it looks like they found the problem you're seeing in 10 SP5 and fixed it in 10.1. I guess they could have fixed it without knowing the problem ever existed. I'm still new to ArcGIS, so I don't know how willing ESRI is to fix bugs in previous service packs, especially when they are fixed in later versions.If this as we both seem to suspect (ArcGIS 10 SP5 has a serious bug; most likely a memory leak), then I don't think there is much left that we can do. To me, it seems your options are to either convince your customer to move to 10.1 (harder than it sounds, I'm sure) or convince ESRI to patch an old version. Have you compared memory usage between my implementation and yours on 10.1? What are the differences? Probably don't need to use UMDH, just task manager.
Hi, Jason!So what about my achievements in the test.As would be expected I run your test app and it did not succeeded.At last i have downloaded and installed the ArcGIS 10.1 with SDK. Both apps (mine and yours) succeeded with it. The model was imported to the GDB featureclass. But it is viewed without textures with the ArcScene and ArcGlobe.The model imported using the Add-in command in ArcGIS 10 has textures. It is not a critical issue (i mean the lost textures) since the model has been imported. It more important for me that the import fails with the ArcGIS 10 since I'm constrained to use the 10th version by the customer.Maybe you have some thoughts else about the problem. Also i think it's a bug that is necessary to report. Worst of all that such a problem was encountered by me to this moment fairly often with the models of different siz
Welcome back, Alexey.I looked at your UMDH logs and I really wasn't able to get anymore information than I already have.I'm not sure what our configuration differences are, but my code is definitely succeeding. I've attached screenshots and all of the code (without the model.) Perhaps you can try my project and see if you have better luck with it?Let me know if the screenshots look as you would expect them to (in the case of success.) Also, let me know if the project I sent you does any better.Thanks!
Hi, Jason.I was away on business and couldn't to proceed with testing. So now i able and would like to go on it.So, I use the included file geodatabase in my test app. I use it in the actual command too. As is easy to see i delete it each execution time and create the new one. In the command i invoke the Import3DFiles method of the test app.I tried your suggestions to release GDB and IFieldChecker. Also i found out that i open it in the Main procedure. It was commented. All of that reduced the memory increase registered in the umdh log for a half. But it is still almost 250MB (instead of ~500MB).Also i tried to make the second capture after all releases that decreased the amount of memory with the result "Total decrease ==253812936 requested + 25696 overhead = 253838632". The last portion of the log contains the above-mentioned memory decrease about 250MB. But, it seems to me such a method is not correct as the registered memory decrease produced by the releasing the featurebuffer itself (exactly determined).Also I executed your code and it finished with no exceptions. BUT!!! You omitted the catch block. At last the main result of the execution and the confirmation of the successful import completion is the GDB featureclass with the imported model within. But the resulting nor mine nor yours GDB does not contain it. If i give the catch block back the exception is registered. Please check up the GDB featureclass for the imported model. It's table should contain the single row, moreover you should be able to zoom to it and to visualize it in the ArcGlobe app, otherwise the code execution did not succeed.I attached the umdh logs made with different captures (after all releases, in the catch block - after the InsertFeature exception, after releasing the FeatureBuffer)
I have to ask because I'm very curious about this, when you are releasing COM objects you always do something like this: try { row = cursor.NextRow(); while(row != null) { //some logic Marshal.ReleaseComObject(row) row = null; row = cursor.NextRow(); } } finally { if(row =! null) Marshal.ReleaseComObject(row); Marshal.ReleaseComObject(cursor); } Now let's analyze this, in loop you are releasing the row object every time and assinging it's value to null - because as you said/wrote somewhere you want to make sure the row object will be destroyed/released. But what about the finally section: if the row object is not null you are releasing it by ReleaseComObject method...but the ReleaseComObject method only decreases the amount of references by 1, so there is a slight possibility that a row object won't be released completely, right? Should we use the FinalReleaseComObject method then? I know that your code examples for releasing COM objects are helping but I'm just willing to learn as much as I can, since COM objects generate so much problems for .net developers in esri products.Regards,MDruzgala
try { // increments RCW's ref count for the current instance of // row by 1 row = cursor.NextRow(); while(row != null) { // some code // decrement RCW's ref count by 1 (it was only incremented // by 1 as seen above) Marshal.ReleaseComObject(row) // set the row equal to null in case the following statements // throw an exception if the an exception is thrown before // row is assigned to a new instance we will enter the // finally-block on our way out of the method. if this happens // and we're still point to the current row its reference count // will be decremented a second time so it will now be -1 row = null; // set row to the next row and increments its RCW's ref // count for the current instance of row by 1 row = cursor.NextRow(); } } finally { // in non-exceptional cases, row will be null and we // will not have to call release. if an exception occurs // and row is not equal to null, then it wasn't released (we // know this because we always set it to null after we release it) if(row != null) Marshal.ReleaseComObject(row); // I don't see where cursor was set... if you don't increment // the RCW's ref count (it was passed in as a parameter from // managed code), you don't decrement it Marshal.ReleaseComObject(cursor); }
Here is part 2: private static IFeatureClass GetFeatureClass(string GDBFilename, string Dataset, ISpatialReference DatasetSpatialReference) { IWorkspaceFactory wsf = null; IWorkspace datasetWorkspace = null; IFeatureClass objectiveFeatureClass = null; try { wsf = new FileGDBWorkspaceFactoryClass(); datasetWorkspace = wsf.OpenFromFile(GDBFilename, 0); if (!((IWorkspace2)datasetWorkspace).get_NameExists(esriDatasetType.esriDTFeatureClass, Dataset)) objectiveFeatureClass = CreateFeatureClass(Dataset, DatasetSpatialReference, datasetWorkspace); else objectiveFeatureClass = ((IFeatureWorkspace)datasetWorkspace).OpenFeatureClass(Dataset); } finally { if( wsf != null ) Marshal.ReleaseComObject(wsf); if( datasetWorkspace != null ) Marshal.ReleaseComObject(datasetWorkspace); } return objectiveFeatureClass; } private static IFeatureClass CreateFeatureClass(string Dataset, ISpatialReference DatasetSpatialReference, IWorkspace datasetWorkspace) { IFeatureClass objectiveFeatureClass = null; IField shapeField = null; IGeometryDef geometryDef = null; IField oidField = null; IFields fcFields = null; IEnumFieldError enumFieldError = null; IFields validatedFields = null; IFieldChecker fieldChecker = null; IObjectClassDescription objectDescription = null; try { shapeField = new FieldClass(); IFieldEdit fieldEdit = (IFieldEdit)shapeField; fieldEdit.Name_2 = "Shape"; fieldEdit.Type_2 = esriFieldType.esriFieldTypeGeometry; geometryDef = new GeometryDefClass(); IGeometryDefEdit geometryDefEdit = (IGeometryDefEdit)geometryDef; geometryDefEdit.GeometryType_2 = esriGeometryType.esriGeometryMultiPatch; geometryDefEdit.GridCount_2 = 1; geometryDefEdit.set_GridSize(0, 0); geometryDefEdit.HasZ_2 = true; geometryDefEdit.HasM_2 = false; geometryDefEdit.SpatialReference_2 = (DatasetSpatialReference != null) ? DatasetSpatialReference : geometryDefEdit.SpatialReference_2 = new UnknownCoordinateSystemClass(); fieldEdit.GeometryDef_2 = geometryDef; oidField = new FieldClass(); fieldEdit = (IFieldEdit)oidField; fieldEdit.Name_2 = "OID"; fieldEdit.Type_2 = esriFieldType.esriFieldTypeOID; fieldEdit.Precision_2 = 0; fcFields = new FieldsClass(); IFieldsEdit fcFieldsEdit = (IFieldsEdit)fcFields; fcFieldsEdit.AddField(shapeField); fcFieldsEdit.AddField(oidField); fieldChecker = new FieldCheckerClass(); fieldChecker.ValidateWorkspace = datasetWorkspace; fieldChecker.Validate(fcFields, out enumFieldError, out validatedFields); objectDescription = new FeatureClassDescriptionClass(); objectiveFeatureClass = ((IFeatureWorkspace)datasetWorkspace).CreateFeatureClass( Dataset, validatedFields, null, objectDescription.ClassExtensionCLSID, esriFeatureType.esriFTSimple, shapeField.Name, ""); } finally { if (shapeField != null) Marshal.ReleaseComObject(shapeField); if (geometryDef != null) Marshal.ReleaseComObject(geometryDef); if (oidField != null) Marshal.ReleaseComObject(oidField); if (fcFields != null) Marshal.ReleaseComObject(fcFields); if (enumFieldError != null) Marshal.ReleaseComObject(enumFieldError); if (validatedFields != null) Marshal.ReleaseComObject(validatedFields); if (fieldChecker != null) Marshal.ReleaseComObject(fieldChecker); if (objectDescription != null) Marshal.ReleaseComObject(objectDescription); } return objectiveFeatureClass; } }
private static IGeometry get_MultiPatchFootprint(IMultiPatch multiPatch) { IPoint centroid = null; IVector3D xVector = null; IVector3D zVector = null; ITransform2D transformer3D = null; try { centroid = ((IArea)multiPatch).Centroid; centroid.Z = 0; xVector = new Vector3DClass(); xVector.SetComponents(10, 0, 0); zVector = new Vector3DClass(); zVector.SetComponents(0, 0, 10); transformer3D = (ITransform2D)((ITransform3D)multiPatch).ProjectToPlane(centroid, xVector, zVector); transformer3D.Move(centroid.X, centroid.Y); } finally { if (zVector != null) Marshal.ReleaseComObject(zVector); if (xVector != null) Marshal.ReleaseComObject(xVector); if (centroid != null) Marshal.ReleaseComObject(centroid); } return (IGeometry)transformer3D; } public static void Import3DFiles(object data) { ISpatialReference datasetSpatialReference = null; ISpatialReference geoSpatialReference = null; IFeatureClass objectiveFeatureClass = null; IFeatureBuffer featureBuffer = null; IFeatureCursor featureCursor = null; try { GetSpatialReferences(out datasetSpatialReference, out geoSpatialReference); Array dataArray = (Array)data; string GDBFilename = dataArray.GetValue(0).ToString(); string Dataset = dataArray.GetValue(1).ToString(); objectiveFeatureClass = GetFeatureClass(GDBFilename, Dataset, datasetSpatialReference); ISchemaLock schemaLock = (ISchemaLock)objectiveFeatureClass; IFeatureClassLoad featureClassLoad = (IFeatureClassLoad)objectiveFeatureClass; schemaLock.ChangeSchemaLock(esriSchemaLock.esriExclusiveSchemaLock); featureClassLoad.LoadOnlyMode = true; featureBuffer = objectiveFeatureClass.CreateFeatureBuffer(); featureCursor = objectiveFeatureClass.Insert(true); List<GeoReferencedModel> Files = dataArray.GetValue(2) as List<GeoReferencedModel>; foreach (GeoReferencedModel geoReferencedModel in Files) { InsertModel(geoSpatialReference, datasetSpatialReference, featureBuffer, featureCursor, geoReferencedModel); } featureCursor.Flush(); featureClassLoad.LoadOnlyMode = false; schemaLock.ChangeSchemaLock(esriSchemaLock.esriSharedSchemaLock); } finally { if (featureCursor != null) Marshal.ReleaseComObject(featureCursor); if (featureBuffer != null) Marshal.ReleaseComObject(featureBuffer); if (objectiveFeatureClass != null) Marshal.ReleaseComObject(objectiveFeatureClass); if (datasetSpatialReference != null) Marshal.ReleaseComObject(datasetSpatialReference); if (geoSpatialReference != null) Marshal.ReleaseComObject(geoSpatialReference); } } private static void GetSpatialReferences(out ISpatialReference spatialReference, out ISpatialReference geoSR) { ISpatialReferenceFactory3 srFactory = null; IVerticalDatum verticalDatum = null; ILinearUnit unit = null; IVerticalCoordinateSystemEdit vcsEdit = null; try { srFactory = new SpatialReferenceEnvironmentClass(); IProjectedCoordinateSystem pcs = srFactory.CreateProjectedCoordinateSystem(32639); spatialReference = (ISpatialReference)pcs; ISpatialReferenceResolution srResolution = (ISpatialReferenceResolution)spatialReference; srResolution.ConstructFromHorizon(); srResolution.SetDefaultMResolution(); srResolution.SetDefaultXYResolution(); srResolution.SetDefaultZResolution(); ISpatialReferenceTolerance srTolerance = (ISpatialReferenceTolerance)spatialReference; srTolerance.SetDefaultMTolerance(); srTolerance.SetDefaultXYTolerance(); srTolerance.SetDefaultZTolerance(); verticalDatum = srFactory.CreateVerticalDatum((int)esriSRVerticalDatumType.esriSRVertDatum_SeaLevel); IHVDatum hvDatum = verticalDatum as IHVDatum; unit = srFactory.CreateUnit((int)esriSRUnitType.esriSRUnit_Meter) as ILinearUnit; vcsEdit = (IVerticalCoordinateSystemEdit)new VerticalCoordinateSystemClass(); int positive = 1; double shift = 0; vcsEdit.DefineEx("", "", "", "", "", hvDatum, unit, ref shift, ref positive); ((ISpatialReference3)spatialReference).VerticalCoordinateSystem = (IVerticalCoordinateSystem)vcsEdit; ISpatialReferenceResolution sprefResolution = (ISpatialReferenceResolution)spatialReference; sprefResolution.SetDefaultZResolution(); srTolerance = (ISpatialReferenceTolerance)spatialReference; srTolerance.SetDefaultZTolerance(); spatialReference.Changed(); IGeographicCoordinateSystem gcs = srFactory.CreateGeographicCoordinateSystem(4326); geoSR = (ISpatialReference)gcs; srResolution = (ISpatialReferenceResolution)geoSR; srResolution.ConstructFromHorizon(); srResolution.SetDefaultMResolution(); srResolution.SetDefaultXYResolution(); srResolution.SetDefaultZResolution(); srTolerance = (ISpatialReferenceTolerance)geoSR; srTolerance.SetDefaultMTolerance(); srTolerance.SetDefaultXYTolerance(); srTolerance.SetDefaultZTolerance(); } finally { if (vcsEdit != null) Marshal.ReleaseComObject(vcsEdit); if (unit != null) Marshal.ReleaseComObject(unit); if (verticalDatum != null) Marshal.ReleaseComObject(verticalDatum); if( srFactory != null ) Marshal.ReleaseComObject(srFactory); } } private static void InsertModel(ISpatialReference geoSR, ISpatialReference DatasetSpatialReference, IFeatureBuffer featureBuffer, IFeatureCursor featureCursor, GeoReferencedModel geoReferencedModel) { IGeometry multiPatch = null; IPoint placement = null; IGeometry footprint = null; try { //reading lat,long and other values values from files with own SketchUpReader (for *.skp) and ZipForge, XDocument (for *.kmz) //do not use any ArcObjects placement = geoReferencedModel.get_Placement(); placement.SpatialReference = geoSR; ((IZAware)placement).ZAware = true; placement.Project(DatasetSpatialReference); //get Z value from IFunctionalSurface (relief raster) placement.Z = 0; //just for test if (!placement.Z.Equals(double.NaN)) { multiPatch = geoReferencedModel.get_MultiPatch(placement, DatasetSpatialReference); if (multiPatch != null) { //here i compute a footprint of multipatch and store it in another featureclass footprint = get_MultiPatchFootprint((IMultiPatch)multiPatch); featureBuffer.Shape = multiPatch; featureCursor.InsertFeature(featureBuffer); } } } finally { if (footprint != null) Marshal.ReleaseComObject(footprint); if (multiPatch != null) Marshal.ReleaseComObject(multiPatch); if (placement != null) Marshal.ReleaseComObject(placement); } }
So, i have followed your instructions and received the results. I'm not good in such debugging, so can't to evaluate it enough. I think you mean something about this when was talking about leaks (just one example): + 249397232 ( 249397232 - 0) 1 allocs BackTraceF3D0738 + 1 ( 1 - 0) BackTraceF3D0738 allocations ntdll!RtlUlonglongByteSwap+00000B52 MSVCR90!malloc+00000079 FileGDB!DllRegisterServer+000053E8 FileGDB!DllCanUnloadNow+0001C5DA FileGDB!???+00000000 : 69BC62F5 FileGDB!???+00000000 : 69BC694A RPCRT4!NdrServerInitialize+00000240 RPCRT4!NdrStubCall2+00000256 ole32!WdtpInterfacePointer_UserUnmarshal+0000256F OLEAUT32!CreateErrorInfo+00000268 ole32!WdtpInterfacePointer_UserUnmarshal+000025FF ole32!WdtpInterfacePointer_UserUnmarshal+00002B59 ole32!CoTaskMemFree+00001B02 ole32!CoTaskMemFree+000019F7 ole32!DcomChannelSetHResult+000008FF ole32!WdtpInterfacePointer_UserUnmarshal+00002A56 ole32!WdtpInterfacePointer_UserUnmarshal+000028CA ole32!WdtpInterfacePointer_UserUnmarshal+00002F86 ole32!DcomChannelSetHResult+0000075C ole32!DcomChannelSetHResult+0000071B USER32!gapfnScSendMessage+00000332 USER32!GetThreadDesktop+000000D7 USER32!CharPrevW+00000138 USER32!DispatchMessageW+0000000F ole32!CoWaitForMultipleHandles+00004311 ole32!CoWaitForMultipleHandles+000023C1 ole32!CoWaitForMultipleHandles+00004332 ole32!CoGetTreatAsClass+00002619 ole32!CoGetTreatAsClass+0000314B KERNEL32!BaseThreadInitThunk+00000012 ntdll!RtlInitializeExceptionChain+00000063 ntdll!RtlInitializeExceptionChain+00000036 + 249397232 ( 249397232 - 0) 1 allocs BackTraceF3D084C + 1 ( 1 - 0) BackTraceF3D084C allocations ntdll!RtlUlonglongByteSwap+00000B52 MSVCR90!malloc+00000079 FileGDB!DllCanUnloadNow+0000BB14 FileGDB!DllCanUnloadNow+0001C6F4 FileGDB!???+00000000 : 69BC62F5 FileGDB!???+00000000 : 69BC694A RPCRT4!NdrServerInitialize+00000240 RPCRT4!NdrStubCall2+00000256 ole32!WdtpInterfacePointer_UserUnmarshal+0000256F OLEAUT32!CreateErrorInfo+00000268 ole32!WdtpInterfacePointer_UserUnmarshal+000025FF ole32!WdtpInterfacePointer_UserUnmarshal+00002B59 ole32!CoTaskMemFree+00001B02 ole32!CoTaskMemFree+000019F7 ole32!DcomChannelSetHResult+000008FF ole32!WdtpInterfacePointer_UserUnmarshal+00002A56 ole32!WdtpInterfacePointer_UserUnmarshal+000028CA ole32!WdtpInterfacePointer_UserUnmarshal+00002F86 ole32!DcomChannelSetHResult+0000075C ole32!DcomChannelSetHResult+0000071B USER32!gapfnScSendMessage+00000332 USER32!GetThreadDesktop+000000D7 USER32!CharPrevW+00000138 USER32!DispatchMessageW+0000000F ole32!CoWaitForMultipleHandles+00004311 ole32!CoWaitForMultipleHandles+000023C1 ole32!CoWaitForMultipleHandles+00004332 ole32!CoGetTreatAsClass+00002619 ole32!CoGetTreatAsClass+0000314B KERNEL32!BaseThreadInitThunk+00000012 ntdll!RtlInitializeExceptionChain+00000063 ntdll!RtlInitializeExceptionChain+00000036 The total result is Total increase == 498797272 requested + -496 overhead = 498796776 Memory was marked just before the call of the InsertFeature code line and after it in the catch code block. I used MessageBox to signal about the mark moments. I debugged the application in different situations as the different exceptions was get, i.e. compilied against the 3.5 and 4.0 .NET Frameworks and the procedure call in current and concurrent thread. All the times memory usage was increased. I uploaded the zip with the debug results. http://dl.dropbox.com/u/91176632/DebugInfo.zip They also contains lines with <no module> and the "?" signs, that is not good for me, i think. <no module>!???+00000000 : F13103B ... MSCTF!???+00000000 : 75931826 ... and so on I should also note that today i tried to execute the application code from the Add-In for the ArcGlobe app and it succeeded. It makes me to think that the ESRI applications are initialized in a special way or i don't make all the necessary initialization steps in my standalone application to make it work properly. Unfortunately the ArcObjects Help does not contain any information about this.
IWorkspace datasetWorkspace = wsf.OpenFromFile(GDBFilename, 0);
IFieldChecker fieldChecker = new FieldCheckerClass(); IEnumFieldError enumFieldError = null; IFields validatedFields = null; fieldChecker.ValidateWorkspace = datasetWorkspace; fieldChecker.Validate(fcFields, out enumFieldError, out validatedFields);
INSTALLING THE NECESSARY TOOLS:1. Download Debugging Tools for Windows. You will likely have to download the entire Windows SDK, but you can browse the ISO for the dbg_x86.msi and just install it. Make sure and install the x86 version regardless of your machine's architecture. http://msdn.microsoft.com/en-us/wind.../gg463009.aspx2. Add a User Environment Variable called _NT_SYMBOL_PATH and set its value to this:cache*C:\dev\symbols;SRV*C:\dev\symbols*http://msdl.microsoft.com/download/symbols;SRV*C:\dev\symbols*http://downloads2.esri.com/Support/symbols/This will allow you to resolve the debugging symbols you need.3. Add a System Environment variable called OANOCACHE and set its value to 1. The disables Ole Automation caching, which is necessary to get accurate information about which calls allocated memory. 4. [OPTIONAL] Add the Debugging Tools for Windows path to you User Environment Variables (C:\Program Files (x86)\Debugging Tools for Windows (x86)\ for x64 machines, C:\Program Files\Debugging Tools for Windows (x86)\ for x86 machines)USING UMDH TO ANALYZE PROBLEM:5. Use gflags to turn stack tracing on:gflags -i <name of executable, e.g. Test.exe> +ustIf you are running a standalone application that uses ArcObjects, replace arcmap.exe with the name of your executable.6. Start your application.7. Mark memory before executing the code you suspect is leaking memory by running UMDH:umdh -pn:arcmap.exe -f:mark1.txtNOTE: In some cases, the process runs start to finish with no stops for user input. In this case, you might want to add Console.ReadKey() (and a message to let you know it is waiting) around the area you suspect is leaking memory so you can take snapshots.8. Execute the code that you suspect is leaking memory and the code that you think should release memory.9. Mark memory again after step 8 is complete:umdh -pn:arcmap.exe -f:mark2.txtNOTE: Try taking a snapshot at the point the out-of-memory exception occurs.10. Create a diff file for the two marks:umdh -d mark1.txt mark2.txt -f:results.txtTIP: The -d switch just outputs in decimal format rather than hexadecimal and makes it easier to read.11. Open the text file to find something like the following:<Lots of information about the symbol files that were loaded?...<Stacks for allocated memory in order from highest consumption to lowest consumption> + 1520000 ( 1520000 - 0) 10000 allocs BackTrace106BF720 + 10000 ( 10000 - 0) BackTrace106BF720 allocations ntdll!RtlAllocateHeap+00000274 MSVCR90!malloc+00000079 MSVCR90!operator new+0000001F Geometry!ESRI::Point::Clone+0000000D EngineGraphics!GraphicTracker::AddWithOptions+0000004D EngineGraphics!GraphicTracker::Add+00000051 mscorwks!CLRToCOMWorker+0000019A <no module>!???+00000000 : 3CA70A + 1520000 ( 1520000 - 0) 10000 allocs BackTraceB522378 + 10000 ( 10000 - 0) BackTraceB522378 allocations ntdll!RtlAllocateHeap+00000274 MSVCR90!malloc+00000079 MSVCR90!operator new+0000001F Geometry!ESRI::Point::Clone+0000000D EngineGraphics!GraphicTracker::GetGT+00000087 EngineGraphics!GraphicTracker::AddReplaceGeometryToDraw+00000102 EngineGraphics!GraphicTracker::AddWithOptions+0000019A EngineGraphics!GraphicTracker::Add+00000051 mscorwks!CLRToCOMWorker+0000019A <no module>!???+00000000 : 3CA70ACLEANUP AFTER YOU'RE DONE ANALYZING:Do the following to make sure you machine performance is optimal when you aren't debugging:12. Use the following to turn off stack tracing when you are finished.gflags -i arcmap.exe -ust13. Set OANOCACHE to 0.
Well, I did find some memory leaks. Looks like ESRI uses the open source project Little CMS and either doesn't release something returned from one of its calls, or Little CMS has a memory leak. While 3MB of leaked memory isn't small, I doubt it is your problem. I still can't reproduce the error on my machine, possibly because it doesn't happen in 10.1. So, what we can try next is using UMDH to see what is in memory when your program crashes. I'll post instructions in a different post. Also, it is possible that there is plenty of memory available, but due to improper pinning of GCHandles, the .NET allocator is unable to compact the GCHeap and therefore runs out of available memory. We'd need to use WinDbg, SOS, and SOSEX to find that, so will start with the easy stuff first.+ 2896592 ( 2896592 - 0) 83 allocs BackTrace87C2B4C + 83 ( 83 - 0) BackTrace87C2B4C allocations ntdll!RtlAllocateHeap+00000274 LCMS117LIB!cmsCreateMultiprofileTransform+000005A3
I'm using ArcGIS 10 for Desktop SP5 (ArcView with authorized 3DAnalyst) on a Windows 7 64-bit machine with 16GB of RAM. Also ArcGIS Engine Runtime and ArcGIS Engine Developer Kit are installed (3DAnalyst also authorized).I don't get any build errors at all. The exceptions i getting vary depending on the way of calling the Import3DFiles procedure and the .NET Framework version.For the project compiled against .NET 4.0:If i call it in the separate thread and do not debug it (breakpoint is on the catch block), i get the System.Runtime.InteropServices.COMException:System.Runtime.InteropServices.COMException: Server fault (maybe wrong translation as don't have English in system, sorry) (Exception from HRESULT: 0x80010105 (RPC_E_SERVERFAULT))Error code: -2147417851Source: ESRI.ArcGIS.GeodatabaseTarget Site: System.Object InsertFeature(ESRI.ArcGIS.Geodatabase.IFeatureBuffer)...Module: esriGeoDatabase.dllIf i debug it (breakpoint is on the InsertFeature line of code), i get System.OutOfMemoryException:System.OutOfMemoryException: Out of memory [GeoReferencedObjects3D]HResult: -2147024882Sorce: ESRI GeoDatabaseTarget Site: System.Object InsertFeature(ESRI.ArcGIS.Geodatabase.IFeatureBuffer)...Module: esriGeoDatabase.dllIf i call the tool procedure in the current thread, i get System.Runtime.InteropServices.SEHException:System.Runtime.InteropServices.SEHException: External component threw an exception (maybe wrong translate, sorry)ErrorCode: -2147467259Source: ESRI.ArcGIS.GeoDatabaseTarget Site: System.Object InsertFeature(ESRI.ArcGIS.Geodatabase.IFeatureBuffer)...Module: esriGeoDatabase.dllFor the project compiled against .NET 3.5, i always get the System.Runtime.InteropServices.COMException (Server fault (Exception from HRESULT: 0x80010105 (RPC_E_SERVERFULT))) all times.Attach the screen shots of debug information windows.
I see. The suggestions I made were to get the test project running on your machine. I think that is an important first step. I should mention that I'm using ArcGIS 10.1 for Desktop on a Windows 7 64-bit machine with 8GB of RAM. Please provide this information for your machine. I had made the following changes to the license checkout code:if (licenseInit.InitializeApplication(new esriLicenseProductCode[] { esriLicenseProductCode.esriLicenseProductCodeStandard, new esriLicenseExtensionCode[] { esriLicenseExtensionCode.esriLicenseExtensionCode3DAnalyst }))Also, I stepped through the code and made sure that no exceptions were occurring and that the field was populated when I reached the InsertFeature call.If you get exceptions or build errors, please post them--they will help me determine what is going on on your machine.What build error do you get when you target 4.0?What are the details of the exception you are getting?Thanks!Jason
Ok, i have tried your suggestions. Target platform was set to "x86" just when my primary source solution was started. I think, it was lost when i "extracted" the test project from it. At last i even made the configuration for x86 platform in the solution properties. It doesn't help.Compiled the test project against .NET 3.5 and 4.0. The result is one-exception.Tried to build and execute the project on another PC with the same result.At first run application, maybe, didn't checkout 3DAnalyst license and completed with no errors. Of course it didn't import the test model, even didn't open it (IImport3DFile.CreateFromFile failed). I revealed it while debugging with step into along the code. I revealed also that the application was initialized with an Engine Product Code.So i made some changes to initialize it with an ArcView Product Code (as 3DAnalyst not authorized with Engine). It prevented the application from the "import 3d model" exception but as expected the "insert feature" exception was thrown.Also while testing my primary and test projects i noticed that almost any model with it's size more than 5 MB (i mean kmz models, skp was not tested for "the size restrictions" yet) can't be processed correctly.
Ok. I have downloaded your project and the ZipForge dependency.Here are some of my findings:1) The reason you were getting the COM Exception was most likely because the projects targeted "Any CPU" instead of "x86". I changed it to "x86" and the exception went away.2) The reason you could not compile against .NET 4.0 is because the "Embed Interop Types" property was set to true on the ESRI assembly references. If you change "Embed Interop Types" to false for all the ESRI references in the project, it will build against .NET 4.0.After I got all that sorted out, I stepped through the solution and it succeeded. I succeeded against .NET 3.5 and .NET 4.0. I did notice some places we could improve the COM interop in the code, but we'll look at that later.Please try the changes I suggest above and see if the test project succeeds for you.
Hi, Jason. I created the project. Despite the common logic of the test project and the source, the test project produces another exception, but it occurs at the same operator (insert a feature to the feature class). Depending on the type of call (in the current thread or in new one) it can be the RCP_E_SERVERFAULT exception wit error code -2147417851 or the external object's exception with error code -2147467259. Also the project is based on .NET Framework 3.5 (as it should be for ArcObjects 10). Couldn't to base it on .NET Framework 4.0, and honestly don't realy understand how it happened with my source project. Maybe the difference of exceptions raised by the projects explaned by different framework they are based on. After all the exception remains and it raises constantly.Link to archive http://dl.dropbox.com/u/91176632/Test.zip
Could you post it on Dropbox or some equivalent and post a link?
Of course. I don't have such an ability at home (weekend you know). Once i'll get to office, i'll make it. Such a question. How can i send it, if it's size exceeds the limits for attachments? Only model is 12.8 MB, while limit for zip is 2.00 MB.
Ok. Can you create and send a project that loads that particular model and reproduces the failure? Please include the model in the zip. I'll try to find out what is consuming the memory.I'd also report this as a bug to ESRI.
The problem occur with single model too. No differences bunch of models or single model.
Have you tried only loading the model that has the problem? Or, does the problem only occur if you load a bunch of models and then the model that is having trouble?
To test my code from previous post i prepared a code fragment//for test//may need some correction as was configured and modified on-the-fly from projectISpatialReferenceFactory3 srFactory = new SpatialReferenceEnvironmentClass();IProjectedCoordinateSystem pcs = srFactory.CreateProjectedCoordinateSystem(pcsType);ISpatialReference spatialReference = (ISpatialReference)pcs;ISpatialReferenceResolution srResolution = (ISpatialReferenceResolution)spatialReference;srResolution.ConstructFromHorizon();srResolution.SetDefaultMResolution();srResolution.SetDefaultXYResolution();srResolution.SetDefaultZResolution();ISpatialReferenceTolerance srTolerance = (ISpatialReferenceTolerance)spatialReference;srTolerance.SetDefaultMTolerance();srTolerance.SetDefaultXYTolerance();srTolerance.SetDefaultZTolerance();IVerticalDatum verticalDatum = srFactory.CreateVerticalDatum((int)esriSRVerticalDatumType.esriSRVertDatum_SeaLevel);IHVDatum hvDatum = verticalDatum as IHVDatum;ILinearUnit unit = srFactory.CreateUnit((int)esriSRUnitType.esriSRUnit_Meter) as ILinearUnit;IVerticalCoordinateSystemEdit vcsEdit = (IVerticalCoordinateSystemEdit)new VerticalCoordinateSystemClass();int positive = 1;double shift = 0;vcsEdit.DefineEx("", "", "", "", "", hvDatum, unit, ref shift, ref positive);((ISpatialReference3)spatialReference).VerticalCoordinateSystem = (IVerticalCoordinateSystem)vcsEdit;ISpatialReferenceResolution sprefResolution = (ISpatialReferenceResolution)spatialReference;sprefResolution.SetDefaultZResolution();ISpatialReferenceTolerance srTolerance = (ISpatialReferenceTolerance)spatialReference;srTolerance.SetDefaultZTolerance();spatialReference.Changed();System.Runtime.InteropServices.Marshal.ReleaseComObject(srFactory);List<GeoReferencedModel> models=new List<GeoReferencedModel>();models.Add(new GeoReferencedModel(path_to_model));IWorkspaceFactory2 workspaceFactory = new FileGDBWorkspaceFactoryClass();IWorkspaceName workspaceName = workspaceFactory.Create(System.IO.Path.GetDirectoryName(path_to_fileGDB), System.IO.Path.GetFileName(path_to_fileGDB), null, 0);IName name = (IName)workspaceName;IWorkspace workspace = (IWorkspace)name.Open();System.Runtime.InteropServices.Marshal.ReleaseComObject(workspaceFactory);System.Runtime.InteropServices.Marshal.ReleaseComObject(workspaceName);Import3DFiles(path_to_fileGDB, "GeoReferencedObjects3D", models, spatialReference)I see that the model causing error is large enough (kmz file 13Mb), and may be featureclass can't store such amount of information by igeometry field. If so is, so how i can analyze geometries of 3d files to prevent exceptions with attempts to store them? What is maximum size of such objects?Can't to attach model file because of size restrictions. If you would like i can email it to you.Would be very appreciative for your help.
Can you post code samples for where you are loading models?What language are you using for development?If you are using a .NET language, you can try using CLRProfiler to identify what is consuming the most memory. If it isn't a managed memory issue, you can use UMDH to see what is being allocated on the unmanaged heap.Let me know if I can help.
Hi! I'm developing the 3D modeling GIS software. For 3D city models i use generated from vector data building models and 3d files (Google Earth and SketchUp) with geographic coordinates within. I import such files' geometries with IImport3DFile and store them in multipatch featureclass in file geodatabase. At last I recieved an exception "Out of memory" during IFeatureCursor.InsertFeature. Have to say that there was no such a problem before (with other files). Error appears constantly after processing definite number of files. Geometries i load from them are correct, i processing their footprints and if i don't save them to my featureclass i process them all with no exceptions. After the exception appears program can't work properly at all until restart (looks like ArcObjects crash). How you could understand i use insert cursor with featurebuffer. Tried edit sessions, load mode for featureclass, direct write with WriteFeature and so on... No differences. May anybody help me? Any suggestions? Sorry for my English )
サインインしたメンバーは投稿、更新のフォローなどができます。初めてですか?無料アカウントを登録してください。
