Greetings, I am running into a small problem. SearchCursor documentation states that search cursors can handle multiple field_names yet the below script only returns the first field name explicitly stated in the field_names parameter of the search cursor. If I use an asterisk, it returns the first field name in the list. I need it to return the location_id and lat and long attributes respectively from the view I am querying. Is it possible for a searchcursor to return more than one column / field?
<SPAN class="comment token">#Explicitly defined object IDs known to be conflated in conflation data model</SPAN>
objectIDList <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="number token">55555</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">44444</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="comment token">#small test</SPAN>
<SPAN class="comment token">#gets distinct location_ids</SPAN>
<SPAN class="keyword token">def</SPAN> <SPAN class="token function">getUniqueLocIDs</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN>
tableRegistry <SPAN class="operator token">=</SPAN> os<SPAN class="punctuation token">.</SPAN>path<SPAN class="punctuation token">.</SPAN>join<SPAN class="punctuation token">(</SPAN>conn<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"myView"</SPAN><SPAN class="punctuation token">)</SPAN>
fields <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="string token">'objectid'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'location_id'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'latitude'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'longitude'</SPAN><SPAN class="punctuation token">]</SPAN>
whereExp <SPAN class="operator token">=</SPAN> <SPAN class="string token">"objectid IN {0}"</SPAN><SPAN class="punctuation token">.</SPAN>format<SPAN class="punctuation token">(</SPAN>objectIDList<SPAN class="punctuation token">)</SPAN>
uniqueLocIDs <SPAN class="operator token">=</SPAN> list<SPAN class="punctuation token">(</SPAN>set<SPAN class="punctuation token">(</SPAN><SPAN class="string token">"{0}"</SPAN><SPAN class="punctuation token">.</SPAN>format<SPAN class="punctuation token">(</SPAN>row<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">for</SPAN> row <SPAN class="keyword token">in</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>da<SPAN class="punctuation token">.</SPAN>SearchCursor<SPAN class="punctuation token">(</SPAN>tableRegistry<SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="string token">'location_id'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'latitude'</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> whereExp<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">return</SPAN> list<SPAN class="punctuation token">(</SPAN>uniqueLocIDs<SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">print</SPAN><SPAN class="punctuation token">(</SPAN>getUniqueLocIDs<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
