I'm trying to use the Print widget in the 4.3 JS API. I get the following errors when I test it out.
1. Error executing tool. Export Web Map Task Job ID: jf8ec59473f97475a9649aa039c01190b : Layer "Wetland Mapper": Unable to connect to map server at https://map.com/MapServer. Failed to execute (Export Web Map). Failed to execute (Export Web Map Task).
2. A connection with the server could not be established (WinINet Error while using HTTPS security, 12029), URL = https://map.com/MapServer?f=json
3. A connection with the server could not be established (WinINet Error while using HTTPS security, 12029), URL = https://map.com/arcgis/rest/info?f=json
I've tried using the default GP service and a custom one. Same errors on both. Also I have tried using http and https
