I'm creating an Add-in that lets a user select the type of feature to draw on the map. I've gotten the code for adding points, polygons, and rectangles, but I'd like to add in the capability of drawing polygons in freehand mode. Is there way of doing that? Here's my existing code for the drawing tool
Public Class DrawTool
Inherits ESRI.ArcGIS.Desktop.AddIns.Tool
Public Sub New()
End Sub
Protected Overrides Sub OnUpdate()
End Sub
Protected Overrides Sub OnMouseDown(ByVal arg As ESRI.ArcGIS.Desktop.AddIns.Tool.MouseEventArgs)
MyBase.OnMouseDown(arg)
Dim activeView As ESRI.ArcGIS.Carto.IActiveView = My.ArcMap.Document.ActiveView
Dim rgbColor As ESRI.ArcGIS.Display.IRgbColor = New ESRI.ArcGIS.Display.RgbColorClass()
Dim pGeometry As ESRI.ArcGIS.Geometry.IGeometry5 = GetFeatureFromMouse(activeView)
rgbColor.Red = 255
'Add the user's drawn graphics as persistent on the map.
AddGraphicToMap(activeView.FocusMap, pGeometry, rgbColor, rgbColor)
'Best practice: Redraw only the portion of the active view that contains graphics.
activeView.PartialRefresh(ESRI.ArcGIS.Carto.esriViewDrawPhase.esriViewGraphics, Nothing, Nothing)
End Sub
Public Sub AddGraphicToMap(ByVal map As ESRI.ArcGIS.Carto.IMap, ByVal geometry As ESRI.ArcGIS.Geometry.IGeometry, ByVal rgbColor As ESRI.ArcGIS.Display.IRgbColor, ByVal outlineRgbColor As ESRI.ArcGIS.Display.IRgbColor)
Dim graphicsContainer As ESRI.ArcGIS.Carto.IGraphicsContainer = CType(map, ESRI.ArcGIS.Carto.IGraphicsContainer) ' Explicit Cast
Dim element As ESRI.ArcGIS.Carto.IElement = Nothing
graphicsContainer.DeleteAllElements()
If (geometry.GeometryType) = ESRI.ArcGIS.Geometry.esriGeometryType.esriGeometryPoint Then
' Marker symbols
Dim simpleMarkerSymbol As ESRI.ArcGIS.Display.ISimpleMarkerSymbol = New ESRI.ArcGIS.Display.SimpleMarkerSymbolClass()
simpleMarkerSymbol.Color = rgbColor
simpleMarkerSymbol.Outline = True
simpleMarkerSymbol.OutlineColor = outlineRgbColor
simpleMarkerSymbol.Size = 8
simpleMarkerSymbol.Style = ESRI.ArcGIS.Display.esriSimpleMarkerStyle.esriSMSCross
Dim markerElement As ESRI.ArcGIS.Carto.IMarkerElement = New ESRI.ArcGIS.Carto.MarkerElementClass()
markerElement.Symbol = simpleMarkerSymbol
element = CType(markerElement, ESRI.ArcGIS.Carto.IElement) ' Explicit Cast
ElseIf (geometry.GeometryType) = ESRI.ArcGIS.Geometry.esriGeometryType.esriGeometryPolyline Then
' Line elements
Dim simpleLineSymbol As ESRI.ArcGIS.Display.ISimpleLineSymbol = New ESRI.ArcGIS.Display.SimpleLineSymbolClass()
simpleLineSymbol.Color = rgbColor
simpleLineSymbol.Style = ESRI.ArcGIS.Display.esriSimpleLineStyle.esriSLSSolid
simpleLineSymbol.Width = 5
Dim lineElement As ESRI.ArcGIS.Carto.ILineElement = New ESRI.ArcGIS.Carto.LineElementClass()
lineElement.Symbol = simpleLineSymbol
element = CType(lineElement, ESRI.ArcGIS.Carto.IElement) ' Explicit Cast
ElseIf (geometry.GeometryType) = ESRI.ArcGIS.Geometry.esriGeometryType.esriGeometryPolygon Then
' Polygon elements
Dim simpleFillSymbol As ESRI.ArcGIS.Display.ISimpleFillSymbol = New ESRI.ArcGIS.Display.SimpleFillSymbolClass()
simpleFillSymbol.Color = rgbColor
simpleFillSymbol.Style = ESRI.ArcGIS.Display.esriSimpleFillStyle.esriSFSForwardDiagonal
Dim fillShapeElement As ESRI.ArcGIS.Carto.IFillShapeElement = New ESRI.ArcGIS.Carto.PolygonElementClass()
fillShapeElement.Symbol = simpleFillSymbol
element = CType(fillShapeElement, ESRI.ArcGIS.Carto.IElement) ' Explicit Cast
End If
If Not (element Is Nothing) Then
element.Geometry = geometry
graphicsContainer.AddElement(element, 0)
End If
End Sub
Public Function GetFeatureFromMouse(activeView As ESRI.ArcGIS.Carto.IActiveView) As ESRI.ArcGIS.Geometry.IGeometry5
Dim screenDisplay As ESRI.ArcGIS.Display.IScreenDisplay = activeView.ScreenDisplay
Dim pPointSymbol As New ESRI.ArcGIS.Display.MarkerFillSymbol
Dim pRGBColor As New ESRI.ArcGIS.Display.RgbColor
Dim pPolygonSymbol As New ESRI.ArcGIS.Display.SimpleFillSymbol
Dim pOutline As New ESRI.ArcGIS.Display.SimpleLineSymbol
Dim pRubberBand As ESRI.ArcGIS.Display.IRubberBand2
Try
Select Case Globals.DrawFeatureType
Case "Point"
pRubberBand = New ESRI.ArcGIS.Display.RubberPoint
Case "Polygon"
pRubberBand = New ESRI.ArcGIS.Display.RubberPolygon
Case "Rectangle"
pRubberBand = New ESRI.ArcGIS.Display.RubberEnvelope
Case "Freehand"
System.Windows.Forms.MessageBox.Show("Freehand not coded yet")
Return Nothing
Case Else
System.Windows.Forms.MessageBox.Show("Not coded yet")
Return Nothing
End Select
pGeometry = pRubberBand.TrackNew(screenDisplay, Nothing)
Return pGeometry
Catch ex As Exception
System.Windows.Forms.MessageBox.Show(ex.ToString, "Get Feature")
Return Nothing
End Try
End Function
End Class
