fc = "fishnet" rows = arcpy.UpdateCursor(fc) for row in rows: geom = row.shape row.LowerX = geom.extent.XMin row.UpperX = geom.extent.XMax row.LowerY = geom.extent.YMin row.UpperY = geom.extent.YMax rows.updateRow(row) del row, rows
Hi Wade,one way you could go is with field calculator:1. create fields for centroidX/centroidY of the grids, calculate geometry for them.2. create fields for UpperY, LowerY, LeftX, RightXin field calculator you can then calculate each field:UpperY = centroidY + (gridheight*0.5)LowerY = centroidY - (gridheight*0.5)LeftX = centroidX - (gridwidth*0.5)RightX = centroidX + (gridwidth*0.5)
Going to try the python code above
Here is an example that may help: fc = "fishnet" rows = arcpy.UpdateCursor(fc) for row in rows: geom = row.shape row.LowerX = geom.extent.XMin row.UpperX = geom.extent.XMax row.LowerY = geom.extent.YMin row.UpperY = geom.extent.YMax rows.updateRow(row) del row, rows
サインインしたメンバーは投稿、更新のフォローなどができます。初めてですか?無料アカウントを登録してください。
