I have a field in the attribute table of ArcMap that contains either the value 'Freehold' or 'Leasehold'. I have another field that contains a unique ID of each polygon. I would like to create a third field called 'Short Label' that I can use to label everything from F1..F60 and L1...L60 based on the Tenure in my table. I would then use this as my label field and I would insert a table into the layout as a lookup.
Would anybody be able to help me write a python script to create the short label field based on the Tenure type?
| Tenure | Unique ID | Short Label |
| Freehold | EGL2266995 | F1 |
| Leasehold | NGL4459756 | L1 |
