This is somewhat unique but the concept probably isn't given that we can do a Symbol Feature class or even a set of labels that we can use repetitively.
I created a set of shapefiles from data that gets updated fairly frequently. I export the same shapefiles to a KMZ file as often as they are updated, but before I do, I have to turn off Fields in the Properties function for the shapefile and then apply a set of Aliases as repetitively as the files are updated.
How can I avoid having to do the same procedure? Is there a way I can create a set of aliases that I can access from Properties for the same fields?
I know that part of the problem is that when I use Table to dbase I have to eliminate all spaces and so I need to use underscores, which means that even if I had the correct field names in the spreadsheet I would still have to edit them in the Properties window. Is there a way to do a Find and Replace in Properties for all the underscores?
The main thing is how to make the process work with a consistent use of the correct fields to get the final product.
Daniel Brenner
