I have a script that runs in arcmap Python window. It does a select layer by location then exports the selected features but i need to remove features with Null or empty attributes in a specific filed before acpy.TableToTable but some times there will be none with Null or empty attributes. I am not sure how to do that so if someone could show me how to this it would be awesome.
Currently this is the code i have.
TA = "TAXLOTS"
SP4 = "SUBJECT_PROPERTY"
arcpy.SelectLayerByLocation_management(TA, "WITHIN_A_DISTANCE", SP4, "600 Feet", "NEW_SELECTION")
try:
if int(arcpy.GetCount_management("TAXLOTS").getOutput(0)) > 0:
arcpy.TableToTable_conversion("TAXLOTS", wp, "NOTIFIED_LOTS.dbf")
arcpy.SelectLayerByAttribute_management("TAXLOTS", "CLEAR_SELECTION")
except:
pass<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
