Hello All:
I'm looking to create a Story Map using the wipe feature to show before and after images of a Seattle haz waste remediation. Images of the clean up from Google Maps are attached. What base maps can/should I use to show this change? Are there other ways to illustrate before and after work?
Sean Smith
Sean,
It's usually not a good idea to post more than one thread of the same question. The places thing matters but usually you pick one place to put it (in this case Story Maps or in State) and if you wanted to add it to other places, you would just tag those places like I did above using the @ symbol and then the place name. I would suggest deleting this post and sticking to your main post here:
Story Map Base Map Question
サインインしたメンバーは投稿、更新のフォローなどができます。初めてですか?無料アカウントを登録してください。
