So I have many users direct connecting to many different cells of data and they are updating the data.
If I want the server to run the checks over night, I have to use the datareviewer service controller. Makes sense.
BUT IT ONLY WRITES TO ONE SESSION AND ONLY ALLOWS FOR ONE JOB???
WHAT?? How is that any help whatsoever. That is the exact same as just going to arcmap and using the datareviewer interface. Am I just supposed to sit around and watch the service controller
If I build RBJ checks to check their work and want to use the service to run the checks I have to -
Create an SDE datareviewer
Create an RBJ for 'AOI 1'
Remap and save a copy of the RBJ for 'AOI2, AOI3, AOI87...'
Load EVERY SINGLE ONE OF THOSE RBJS into the Reviewer controller
Let the service run and shove all of the results in the same session.
Get here before everyone else and relink the qc grid since the checker doesn't auto populate that even though it's linked
have the user re link the grid too
Recreate a the reviewer database every now and then so it doesn't get an unusable amount of records in it.
Update 80 different RBJ checks every-time I need to add or change a check, since each rbj has to be mapped to which spacific database it's being run on.
And don't say use the product library. I've set up 20 different product libraries with 100 different data models with 50 different permission levels and it all it does is crash the controller. I can't even get past the testing phase.
Thanks for nothing.
