...One idea that may be the problem is: if your GIS server is not public (e.g., behind a firewall), ArcGIS.com won't be able to generate legends for any services. This is because the utility that generates the legend requires access to the map service. You will be able to view the map service display in the ArcGIS.com map viewer because you're browser is running inside your firewall, and thus can see it. The browser views the service directly and doesn't go through ArcGIS.com....
サインインしたメンバーは投稿、更新のフォローなどができます。初めてですか?無料アカウントを登録してください。
