I would like the subtitle text of my application to change based on user input in the application. Although, I was able to do this, it appeared to corrupt the Header Controller of the theme and I was unable to save any edits in WebApp Builder afterwards. It seems like it may cause a problem because a change in the subtitle prompts the reset of the Save button in WebApp Builder. Is it possible to change the subtitle text from within the application without causing problems with the theme?
Thanks so much.
Brittney
