While in field view I turn off/on certain fields, however when I go to save this change it doesn't let me.
Then when I try to exit from the field view tab I see this.
Is there another way to turn off and on field visibility?
Drew, do you have any active feature edits that are not saved under the map view?
If there are outstanding unsaved edits under the map view then Pro wont let you make changes to the attribute table under the table view.
Hi Drew,
What version of ArcGIS Pro are you using? Also, what type of layer are you working with (i.e. enterprise geodatabase feature class, shapefile, feature service)?
I'm working with ArcPro 2.0.0, working on a polygon layer within a file gdb
Is this reproducible on other feature classes in the same File Geodatabase? In a different File Geodatabase? In a new ArcGIS Pro Project?
Yes, it happens on every layer in my FGDB (including different geometry types). I have not tried with another FGDB however
Somewhat strange... but here is the scoop
Toggle the field off.. unchecking Read Only if necessary.
Save your edits otherwise you get the warning
Close the table
Open the table and the field should be hidden.
Otherwise, just right-click on the field name, and 'hide' field. this isn't permanent and the field will reappear when reopened.
Thanks Dan,
The issue for me is that I am unable to save after making any changes, but the popup warning confirms that changes have been made, despite the save button being greyed out
I would try another File Geodatabase to see if it's something specific with this geodatabase. Also, 2.0.1 is available for ArcGIS Pro. I would recommend upgrading to that version by clicking Project > About.
Forgot to mention... I was using 2.0.1....
Thank you Mervyn, that solved my problem.
My add-in updated the table of attributes but did not save afterwards, preventing me from saving my changes to the tableview.
A pop-up stating that there are unsaved changes pending before the "edit field" interface even comes up would easily solve this problem. Having a button greyed out with no indication as to why is very frustrating and isnt the most intuitive from a UI design perspective.
If you hover over the save field changes icon, a banner comes up stating that there are unsaved feature edits. You're right though, this is not at all intuitive and took me awhile to figure out.
Thanks - I had that question too!
outstanding edits saved > still unable to save new fields added...
check/uncheck visible a fix for me...
yup... a pop-up or something more intuitive/instructional than greyed out would greatly assist UX.
Ridiculous how steep this 'migrate prod env to pro' curve is proving...
hoping the long term efficiency gains are worth the short term pains and inefficiencies
Running 2.2.2, and have this same issue. It seems like a bug to me - You first have to save the edits before making a field visible or not? Makes me miss the ArcMap fields tab.
In case anyone else discovers this in the future, just to be clear: this pertains to unsaved changes to any layer in ArcGIS Pro, not just the target layer to which you are attempting to change the schema.
I can't find how to save feature edits
Hi Dianne,
You've likely made edits to features either in a map or scene. So click on the map tab, and you should see an Edit tab become available on the ribbon. In the edit tab, Save and Discard should be enabled if you have outstanding edits.
Mine are grayed out as I don't have any pending edits.
I hope this helps.
Mine are grayed out too but I apparently still have unsaved feature edits. I checked and I cannot see anything that would be unsaved.
Any other possible issues I am missing?
Thanks Dan. It worked after I toggled on/off. That was weird.
This does the job for me. Thank you!!!
Such a ridiculous error.
Using Version 3.1. Still seems like a bug and/or something that could be improved upon. I saved all edits and and the 'edit save' button was greyed out...and I was having issues as everyone else here in not being able to save edits to the fields.
サインインしたメンバーは投稿、更新のフォローなどができます。初めてですか?無料アカウントを登録してください。
