Hey,Building off of the infoWindow with tabs example. Currently I am dynamically building some tabs, e.g.:var tc = new dijit.layout.TabContainer({ style : "width:100%;height:250px;" }, dojo.create('div')); forEach(myData,function(data){ var cp1 = new dijit.layout.ContentPane({ title: "A title"}); cp1.setContent(layerTabContent(data)); // create an html table from data for tab content tc.addChild(cp1); });The above works fine (though is really ugly, later I have to find the CSS that drives the tabs).I can take an infoWindow template:template.setContent(tc.domNode); graphic.setInfoTemplate(template);
and these generated tabs show in the infoWindow. Now above these tabs I want an header of information for that point, e.g. address info:var html = '<div><table><tr><td><img src="icon.png"></td>'; html += '<td><span>' + feature.attributes["Address"] + '</span><br/>'; html += '</td></tr></table></div>';
if I were to setContent simply as this html that would work find, e.g.:template.setContent(html); graphic.setInfoTemplate(template);
However, the issue is how to combine the tc.domNode with the html, since they are currently of different object types.Thoughts?Thanks!
