I know this information is out there but I guess I'm not searching for it Correctly:
I'm looking for an example using a python script to publish a map service using an .mxd file.
You might want to look at the ArcGIS Server Administrator toolkit
http://www.arcgis.com/home/item.html?id=12dde73e0e784e47818162b4d41ee340 which has
...tools for starting and stopping services, modifying log settings, registering server object extensions (SOEs), and publishing services from service definition files.
old blog Downloadable tools for ArcGIS Server administration | ArcGIS Blog
(The tools are a starting point, although you may need to update for your purposes. For example, I have modified some of the scripts to do things like find running services that use datasource X.gdb then stop those services, replace the fgdb, then start just those back up (instead of trying to remember which you stopped). There is a never beta version of those tools..but I don't have the link handy.)
Also check out
CreateMapSDDraft—Help | ArcGIS for Desktop
PublishMSDToServer—Help | ArcGIS for Desktop
and some of the related links to get started.
An old question on Geonet:
How to publish a feature service to ArcGIS Online from an mxd USING PYTHON?
Which leads to this blog post (last comment suggests code -on GitHub- can be made to work with 10.5):
Updating your hosted feature service for 10.2
If you want to write your own script, you'll need to use the Create Map SD Draft tool, Stage Service tool, and Upload Service Definition tool.
サインインしたメンバーは投稿、更新のフォローなどができます。初めてですか?無料アカウントを登録してください。
