I'm just starting to explore Story Maps. I would like some information on the Story Map "Seven Wonder: The Ancient World" located at Seven Wonders: The Ancient List . There's also the Seven Wonders: the New List at Seven Wonders: The New List which I discovered only by following a link at the bottom of the text describing the 7th wonder.
Q1: When I'm viewing the story map is there a creator attribution field where I can see who created it in order to give appropriate credit? I think these were both created by the Esri Story Map Team, but I don't see that anywhere. How can I determine that information?
Q2: Also, were these two story maps created using one of the Story Map templates, and if so, which template? I scrolled through the gallery of examples to find an example like it, but don't see anything quite like it with 2 fixed panels on the left-hand side, where the lower panel can be clicked forward and back < > to proceed in sequence. Which template should be used to produce that effect?
Mia
